Unity Voice Mail Problem
Jan 9th, 2008
I have problem with unity recently some phones where moved from one location to another. So the partition and CSS where changed accordingly. The phones ring fine apart from when they are being forwarded to VM then it rings engaged although the old number forwards them fine. The new number is 01606 275303 and the old number was 01270 275303.
Any help appreciated.
Kev
Rob Huffman Wed, 01/09/2008 - 05:44
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Kev,
Sounds like it may be a CSS issue on the Call Forward CSS. Can these phones call the Unity Pilot #? If so, maybe you could try applying the same CSS that is used for the Line or Device (whichever you are using) to the Call Forward CSS.
Hope this helps!
Rob
kevinhobson2000 Thu, 02/21/2008 - 07:20
Rob,
It would appear that the second call that is passed to Unity is ringing engaged. Any idea what would cause this?
Kev
