01-09-2008 06:19 AM
I have a Linux server inside the firewall. Just purchased and installed ASA5505 bundle with Smartnet.
The Linux server sends backup result messages to our Exchange server. It does this by accessing an external port/IP address. This no longer works since upgrading to ASA5505. I have searched every mutt, sendmail, etc that I can on the Linux box. Any advise would be greatly appreciated.
Thanks.
01-09-2008 08:02 AM
You need to add another static in your ASA. Here's a link for reference. If you still have questions, let us know.
http://blogs.interfacett.com/mike-storm/2006/6/29/bidirectional-nat-on-a-cisco-pix-or-asa.html
HTH and please rate.
01-09-2008 09:02 AM
Thanks very much for the link.
I have passed this on, as this is starting to get outside of my realm.
Brian
01-09-2008 08:06 AM
Brian
I can not tell from your post whether you have configured the ASA to permit it to forward traffic back out the same interface on which it was received. By default the ASA does not do this. To configure it you would use this command:
same-security-traffic permit intra-interface
Rick
01-09-2008 08:21 AM
This should do it. It may look slightly different depending upon your current configuration.
global (inside) 1 interface
nat (inside) 1 0 0
static (inside,inside)
01-09-2008 09:02 AM
Thanks very much for the reply.
We will be testing this over the next day or so.
Brian
01-09-2008 09:03 AM
Thanks Rick.
I will be looking into all of this in the next day or so.
Brian
