Outgoing caller ID on FXO ports
Jan 9th, 2008
Is there a way to specify caller ID outgoing on FXO ports in CME or is that just controlled by the phone company? I have someone that wants people they call to see their main number whichever FXO port they call from instead of the number for each of the individual analog lines.
Rob Huffman Wed, 01/09/2008 - 07:14
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Brian,
Yes, this is something that is set by the Telco Provider.
Hope this helps!
Rob
mpitts Tue, 01/15/2008 - 07:55
You may also be able to add the following command to your outbound dial peer(s)-
clid network-number xxxxxxxxxx (your main number)
In some cases the Telco may not accept it, but if they do it works fine.
Mike
paolo bevilacqua Tue, 01/15/2008 - 08:16
  • Hall of Fame,
    Founding Member
But this doesn't work for FXO (analog) lines.
Just like you will never be able to change the caller-id to show when you call from home.
