01-09-2008 06:51 AM - edited 03-03-2019 08:11 PM
I have two routers at a central location. One is handling data communications and the other is handling voice communications. Data router died recently with a power supply issue. Power supply replaced, communications is back up. Now having other issues cropping up with sporadic ping failures from two servers and voice issues. The Sh Tech has been provided. Any assistance would be greatly appreciated.
01-09-2008 07:44 AM
I see that the FastEthernet0/0 of the router that handles data communications has had 10 interface resets since the router came back up (that is 10 interface resets in almost 6 days). Check your FastEthernet physical connection, because it could have been slightly "shaken" while you were around the router trying to solve the power supply issue.
Kind Regards,
M.
01-09-2008 08:57 AM
01-09-2008 09:35 AM
Try to describe the problem you are experiencing with more details. For example, how did you become aware of the problem (e.g. users in particular LAN complaining), where do you initiate your ping efforts, what do those ping efforts target to reach, what path in your network are they supposed to go through, things like that.
Please post the logs from your devices, so we can see the latest events.
In the meantime, you might want to check if your speed and duplex settings are those they are supposed to be, because I see that all the devices you supplied information about have been reset the last week and perhaps some configuration settings where "lost" in this process.
Kind Regards,
M.
01-09-2008 10:08 AM
01-09-2008 10:24 AM
