Cross VLAN Traffic Problem
Jan 9th, 2008
I have a switch which is layer 2, it is having IP address. The firewall interfaces connect it but in different VLANS. When I try to ping the switch with its IP address then Reply is going to the outside interface, but does not come back; I have checked the syslog server and found that the reply comes back on to the other interface of firewall. It is quite confusing as per the basic functionality. I have checked the config on the ASA but did not find something specific. Can any one of u suggest something. As per my understanding the data of one VLAN is going to the other VLAN. All suggesstions are appriciated.
Best Regards
Mohsin
irisrios Wed, 01/16/2008 - 07:55
  • Silver, 250 points or more
Are you sure reply comes back to the other interface. Check if the inter-VLAN routing is enabled between VLANs with the help of a router for the communications to happen properly.
