CSCOjre14 - Correcting pkgchk errors
Jan 9th, 2008
  • Gold, 750 points or more
When updating CS 3.0.5 to 3.0.6 on the CLI, it's hung up at:
Installing Java Runtime Environment 1.4.2_04 as <CSCOjre14>
## Installing part 1 of 1.
## Executing postinstall script.
INFO: /var/sadm/pkg/CSCOjre14/install/postinstall started at Wed Jan 9 11:25:28 EST 2008
INFO:Updating for NZ DST change
/product/CSCO/CSCOpx/lib/jre/bin/java not directly found in contents file, no package resolution performed.
(May not be in PKG form, not an absolute path, or is a symlink.)
INFO: /var/sadm/pkg/CSCOjre14/install/postinstall finished at Wed Jan 9 11:25:35 EST 2008
Installation of <CSCOjre14> was successful.
INFO: Package CSCOjre14 - Installed. Correcting pkgchk errors -
When I do a manual "pkgchk CSCOjre14" on the side, I get a very long output:
ERROR: /opt/CSCOpx/lib/jre/lib/zi/Etc/UTC
permissions <0444> expected <0750> actual
ERROR: /opt/CSCOpx/lib/jre/lib/zi/Europe
permissions <0775> expected <0750> actual
ERROR: /opt/CSCOpx/lib/jre/lib/zi/Europe/Amsterdam
ERROR: /opt/CSCOpx/lib/jre/lib/zi/Pacific/Wallis
ERROR: /opt/CSCOpx/lib/jre/lib/zi/Pacific/Yap
pathname does not exist
ERROR: /opt/CSCOpx/lib/jre/lib/zi/WET
ERROR: /opt/CSCOpx/lib/jre/lib/zi/ZoneInfoMappings
file size <13177> expected <13859> actual
file cksum <29989> expected <24186> actual
ERROR: /opt/CSCOpx/setup
permissions <0750> expected <0755> actual
ERROR: /opt/CSCOpx/setup/patch/CSCse85012-0.info
file size <137> expected <163> actual
file cksum <10995> expected <12308> actual
Is it taking its time fixing the errors, or has it stalled? This is a test box. On the prod box, "pkgchk CSCOjre14" returns:
file cksum <10995> expected <12304> actual
yjdabear Wed, 01/09/2008 - 09:09
Alright, it finally moved on. Then it spent a little time on CSCOcore, and now appears to be fixing "CSCOtmct" pkgchk errors. Are these of concern?
Joe Clarke Wed, 01/09/2008 - 09:24
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
These errors should be fixable, and should not cause any problems. Fixing pkgchk errors are typical during the installation, especially if you have applied point patches.
