01-09-2008 08:56 AM - edited 03-05-2019 08:22 PM
This is probably an easy question, but I can't seem to find a straight answer. Basically, will a Catalyst 6000 support a Sup 720? I have been researching this and I've seen documents that say yes and others that say no. Maybe, there is a specific Sup 720 model for the Cat 6000?
Jim
01-09-2008 09:09 AM
Hi Jim,
Both 6006 and 6009 does not support sup 720. This chassis will not support the high speed fan tray (WS-C6K-6SLOT-FAN2 High-capacity
fan tray for WS-C6506 chassis) that is necessary for the Sup 720s to operate
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/6000hw/supe_gd/01overvw.htm#wp1015129
Ankur
*Pls rate all helpfull post
01-09-2008 09:28 AM
Thank you. This is exactly what I was looking for.
Jim
01-09-2008 09:34 AM
Hi Jim,
Can you please forward me the document which says Cat6000 chassis support sup 720?
Ankur
