Unable to External Redirect with wired WLAN
Jan 9th, 2008
I'm not sure if this is a bug in the GUI or Software I have trid this in both GUI and CLI.
I'm trying to redirect a Wired WLAN to an external Web-Auth server, I'm already doing so successfully with the Wireless lan.
Here is the process :
Wlans -> [WLAN ID] -> Security -> Web Authentication > tick Over-ride Global Config -> Select External (redirect to external server) insert URL and click APPLY.
The problem is that when I press Apply and check you the settings again there has been no change, so I'm still being re-directed to the internal global server.
Anyone had this problem and have a solution for me ?
Thank in advance.
gudmundurk Thu, 01/17/2008 - 01:30
I was able to configure this in the WCS when I finshed connecting the controller to the WCS.
It's quite odd.
Trending Topics - Security & Network
