How do you start/stop subsystems in 4.04?
Jan 9th, 2008
How do you enable/disable and/or start/stop individual subsystems in IPCC Premium 4.04? e.g. Database Subsystem? I can start/stop the CRM engine, but I don't see where the subsystems are configured. Thanks!
Tim
simonandorfi Thu, 01/10/2008 - 06:14
Once you configured a subsystem (e.g. Database Subsystem) this becomes available.
You can control these systems via "System-Control Center", but it is not possible to start / stop them each for themself. They are located under "CRS Engine" and started if Engine is running.
regards, Simon
Riccardo Bua Thu, 01/10/2008 - 06:18
Hi Tim,
the Feature set could be started-stopped-restarted via the serviceability tools, for the individual subsystems you will need to wait for a feature enhancement to be released in the newer releases and this fix will not be rolled back on the 4.0.x train I am afraid.
Riccardo
