mgcp/srst fallback
Jan 9th, 2008
Running 12.4.11 cisco 2811 running mgcp. When wan fails, phones register to gateway, but the gateway does not failover unless it is rebooted. Anyone seen this? Symptoms are inability to make or take a call over the PSTN. Reboot the gateway with wan still down, an bang works.
Tommer Catlin Wed, 01/09/2008 - 14:14
Sounds like a config issue, but is it possible to post your config here?
If the phones are failing over to the gateway, this means the SRST is configured for the device pool correctly. how long do you wait until the gateway is able to make or take calls from the pstn?
whanson Wed, 01/09/2008 - 16:03
it won't unless you reboot the gateway. Calls can be made ip phone to ip phone. It is as if the application service alternate is not working.
