Keepalives
Jan 9th, 2008
I have a question that I'm sure someone on here can help me with....
I have a content rule that is dependant on 2 services....there is a webserver and a database server...in order for that content rule to work properly, both need to be up....doesn't do any good if only the webserver is up and the database server is not...or vice versa...so I need to pull that service out of rotation if EITHER of the servers is down....how can I achieve this?
Thanks in advance
sandeep
eg) the webserver instance needs to be up on port 83 and the database server instance also needs to be up on port 2099 before the CSS will load balance to them...
I hope this makes sense....
Gilles Dufour Thu, 01/10/2008 - 05:55
  • Cisco Employee,
you'll need to create a script similar to ap-kal-tcp-ports. (I would call it ap-kal-tcplist).
See this script @
http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_tech_note09186a00801e1e14.shtml
The idea is to provide not just 1 ip address and several ports, but many tuple (ip address, port).
In your case 2 are enough.
With this script, you can create a global keepalive that will use it with parameters ip1,83,ip2,2099.
The global keepalive will check both devices at the same time.
You can then apply this keepalive to each service.
Gilles.
