7941 on cme 4.2 has bad time display
Answered Question
Jan 9th, 2008
My 7941's loading SCCP41.8-2-2SR2S from CME 4.2 router running 124-11.XW2 (I originally had 124-11.XW1 loaded, same symptom) display GMT time, and not the EDT as configured on my router. Verified phones are pulling time from router by removing ntp server, and putting ntp master on router and giving it an odd time. Phones follow the router, except that the time is +300 min (I am EDT/EST). I still have one 7941 that was initially loaded via CME 4.1 (before I upgraded router), that phone shows the proper time. Anyone else having this issue, or have a recommended fix?
Correct Answer by pcameron about 9 years 4 months ago
The 'error loading locale' is normal as long as you are in the U.S. because it is looking for a tone file that doesn't exist because it is the default setting. You should be OK to ignore it because it won't affect anything.
Refer here for details on CME locale configuration -
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmelocal.html#wp1087072
Try doing this under the telephony-service -
no create cnf-files
create cnf-files
Make sure the correct phone type (7941) is specified under the specific ephone config as well.
Overall Rating: 4.7 (3 ratings)
pcameron Wed, 01/09/2008 - 15:56
  • Cisco Employee,
The 7941/61 phones are Java based and use use the time off the router, but they apply an offset based on the timezone configured under the CME.
Under telephony-service, add the correct time zone -
CME-Switch(config-telephony)#time-zone ?
<1-53> select timezone name used by IP phones (offset in minutes)
1 Dateline Standard Time -720
2 Samoa Standard Time -660
3 Hawaiian Standard Time -600
4 Alaskan Standard/Daylight Time -540
5 Pacific Standard/Daylight Time -480
6 Mountain Standard/Daylight Time -420
7 US Mountain Standard Time -420
8 Central Standard/Daylight Time -360
9 Mexico Standard/Daylight Time -360
10 Canada Central Standard Time -360
11 SA Pacific Standard Time -300
12 Eastern Standard/Daylight Time -300
13 US Eastern Standard Time -300
14 Atlantic Standard/Daylight Time -240
15 SA Western Standard Time -240
16 Newfoundland Standard/Daylight Time -210
17 South America Standard/Daylight Time -180
18 SA Eastern Standard Time -180
19 Mid-Atlantic Standard/Daylight Time -120
20 Azores Standard/Daylight Time -60
21 GMT Standard/Daylight Time +0
22 Greenwich Standard Time +0
23 W. Europe Standard/Daylight Time +60
24 GTB Standard/Daylight Time +60
25 Egypt Standard/Daylight Time +60
26 E. Europe Standard/Daylight Time +60
27 Romance Standard/Daylight Time +120
28 Central Europe Standard/Daylight Time +120
29 South Africa Standard Time +120
30 Jerusalem Standard/Daylight Time +120
31 Saudi Arabia Standard Time +180
32 Russian Standard/Daylight Time +180
33 Iran Standard/Daylight Time +210
34 Caucasus Standard/Daylight Time +240
35 Arabian Standard Time +240
36 Afghanistan Standard Time +270
37 West Asia Standard Time +300
38 Ekaterinburg Standard Time +300
39 India Standard Time +330
40 Central Asia Standard Time +360
41 SE Asia Standard Time +420
42 China Standard/Daylight Time +480
43 Taipei Standard Time +480
44 Tokyo Standard Time +540
45 Cen. Australia Standard/Daylight Time +570
46 AUS Central Standard Time +570
47 E. Australia Standard Time +600
48 AUS Eastern Standard/Daylight Time +600
49 West Pacific Standard Time +600
50 Tasmania Standard/Daylight Time +600
51 Central Pacific Standard Time +660
52 Fiji Standard Time +720
53 New Zealand Standard/Daylight Time +720
If you are EST, then this would be -300, so select option 12.
You then need to use the 'create cnf' command to rebuild all the XML config files for the phones. Reset the handsets and after they re-register the time should be correct.
gerheauserm Thu, 01/10/2008 - 03:22
Thanks for the reply, but have been through all that. The phones are either not reading the config file, or the router is not creating it properly. I even entered different time-zone numbers just to get it to change, but the phone does not, it stays on GMT. I even did the hard reset procedure to force the phones to totally reload, no change. Any of the phones reading the current load/config files do not display the correct time.
One thing I did notice, when running a “debug tftp events” during a hard reset, there are a couple of xml files the phones are looking for, that don't seem to be created. Is it possible the router is not creating all the files it needs to with the create cnf command? Also, when I do a create cnf, and then look at the bottom of the telephony-service part of the config, it shows :
create cnf-files version-stamp 7960 Jan 10 2008 06:14:17
Is it building a config file for the wrong phone type? The only load line I have under that section is for the 7941's:
load 7941 SCCP41.8-2-2SR2S
Scratching head………
Correct Answer
pcameron Thu, 01/10/2008 - 03:57
  • Cisco Employee,
no create cnf-files
create cnf-files
gerheauserm Thu, 01/10/2008 - 04:22
Ah, was missing the phoen type under each ephone config. That fixed that. Now, the only issue I have remaing, is when the phones reset/reload, I see a brief "error loading locale" message. I verified via the "sh telephony" command, that I am on default "0" for US. Is this a quirk that I see proir to it finishing the config load?
Really appreciate your expertise and quick response. Will give you top score on this one.
Correct Answer
pcameron Thu, 01/10/2008 - 04:35
  • Cisco Employee,
