CDR Error CM 6.0.1
Jan 9th, 2008
  • Bronze, 100 points or more
Here is the error I am getting while trying to retrieve call records:
Error 30023 Data not available for the date range selected. Data is available only from Nov 10, 2007 to Dec 9, 2007.
I found reference to the error, but for CM 4.X. I tried to get the records last week and the error was a week earlier too.
Our system installer recommend I open a TAC case, but I wanted to get input from this forum first.
Thanks in advance,
Liz
gogasca Wed, 01/09/2008 - 21:05
  • Green, 3000 points or more
Hi Liz,
Did u make sure that CDR enabled flags were enabled in all servers running CCM service?
It was working before?
Which report you are using?
When you do a CDR search same issue?
Let us know
egrinkin1 Thu, 01/10/2008 - 04:33
Hi, Thanks for your response!
CDR flags enabled. Never tried before the upgrade. I was offered the job here the day they upgraded to 6.0.1.
I get the same error running multiple reports, user, gateway, etc. I get a different error when using CDR search.
10021 There are no matching records.
I ran for the gateway (we only have one) and all day yesterday.
Even if the system was only reporting on me, there would have been results, as I called off-net.
I look forward to your reply.
bluejays Wed, 01/16/2008 - 08:44
I had exact same problem. Before CCM upgrade, CDR is fine but after 4.x to 6.0 upgrade, CDR stopped working.
CDR enabled flag is true for all nodes.
egrinkin1 Wed, 01/16/2008 - 09:34
TAC identified a bug with 6.0.1 and a work around.
Once he completed the work via CLI, restarted the CDR services, and forced the CDR Upload, AND I waited about 2 days, all the records were available.
Here's what he sent me, but he did the work.
Run the following queries fro CLI:
run sql Select max(Error_Record_Id) from car:tbl_error_id_map
returned
Get the result of above query as and run the following:
run sql update car:tbl_system_preferences set param_value= where param_name='MAX_ERROR_RECORD_ID'
for example, if "max(Error_Record_Id) from car:tbl_error_id_map" return 100, then please update 'MAX_ERROR_RECORD_ID' as 101.
Please let me know if this helps.
febinattingal Sun, 08/31/2008 - 23:04
I Have the same error in ccm 5.1.2.
Please check the attached error message.
Is there any bug with ccm?
egrinkin1 Wed, 09/03/2008 - 04:51
This was what I posted a few months back and all that I have on the resolution:
Run the following queries from CLI:
returned
