Dial Backup Through ISDN
Jan 9th, 2008
Dears
How through setting below in test whether the dial backup is connecting isdn.
interface BRI0
ip address 10.10.10.2 255.255.255.0
encapsulation ppp
shutdown
dialer idle-timeout 10800 either
dialer map ip 10.10.10.1 name BIC_CAJAMAR class DOV broadcast 07809211698
dialer redial interval 10 attempts 10
dialer watch-disable 15
dialer watch-group 1
dialer-group 1
isdn switch-type basic-net3
isdn point-to-point-setup
ppp authentication chap
ppp multilink
PAUL TRIVINO Thu, 01/10/2008 - 16:44
First do "no shut" or nothing will work...
Then, you should be able to use the "isdn test call..." command to make a test call and see if all is OK.
Paul
