Cisco WS-C3550-48 GBIC ports!!!
Jan 9th, 2008
Hi can you please help me.
Im planning to connect 2 servers with 1 gig nic on 3550 switch fiber module.
Is there any probelm?
what do i need to check to make sure that i will not encounter any problem?
r all gbics ports hav the same capabilities?
please see below my router show version
Cisco WS-C3550-48 (PowerPC) processor (revision S0) with 65526K/8192K bytes of memory.
Processor board ID CAT0942N5LT
Last reset from warm-reset
Running Layer2/3 Switching Image
Thanks for the help.
Overall Rating: 4 (1 ratings)
Edison Ortiz Wed, 01/09/2008 - 19:42
  • Hall of Fame,
    Founding Member
All Gigabit switchports have the same capability. Can you post the entire show version ?
___
Edison.
iceman0813 Wed, 01/09/2008 - 20:21
Hi ediortiz,
thanks for your reply, plese find below my full show version from 3550 switch.
Cisco IOS Software, C3550 Software (C3550-IPBASE-M), Version 12.2(25)SEB4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
ROM: Bootstrap program is C3550 boot loader
ComputerRoom3550 uptime is 14 weeks, 6 days, 1 minute
System image file is "flash:c3550-ipbase-mz.122-25.SEB4/c3550-ipbase-mz.122-25.SEB4.bin"
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 2 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 12 Fast Ethernet/IEEE 802.3 interfaces
--More--
Ethernet-controller 4 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 5 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 6 has 1 Gigabit Ethernet/IEEE 802.3 interface
48 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
384K bytes of flash-simulated NVRAM.
Motherboard assembly number: 73-5701-10
Power supply part number: 34-0967-03
Motherboard serial number: CAT09430PAN
Power supply serial number: DTH09357W30
Model revision number: S0
Motherboard revision number: A0
Model number: WS-C3550-48-SMI
System serial number: CAT0942N5LT
Configuration register is 0x10F
Thanks.
iceman0813 Wed, 01/09/2008 - 20:25
hi edison,
what can you say about 2 server's connecting on gigabit switch ports?
Is that a bad or good setup? im worried about the problems that I will be encounter in the future.
Thanks.
Edison Ortiz Wed, 01/09/2008 - 21:34
  • Hall of Fame,
    Founding Member
If you aren't planning on connecting other switches (expanding your port count), then using the Gigabit ports should be fine.
Often, those ports are left for inter-switch link because that's where the bandwidth aggregation usually occurs.
HTH,
___
Edison.
iceman0813 Wed, 01/09/2008 - 21:53
Hi edison,
Again thanks for your help and i'm very appreaciated.
I have also plan to connect 3 switches on 3550 via ethernet ports. 2 2950 switches and 1 2960.And will also use VTP and VLAN for 2960 for 10 pc's connected.( my boss wanted me to separate the traffic from 10 pc's connected on 2960)
Is that OK?
BTW the 2 serves that will connect on 3550 has 1 gig NIC.
Thanks and God bless
Edison Ortiz Thu, 01/10/2008 - 05:50
  • Hall of Fame,
    Founding Member
1) You mentioned the 3550 has fiber Gigabit ports. Are you planning to swap those fiber GBICs for copper GBICs for the server connection? You need the module(s) 1000BASE-T GBIC
2) Creating multiple Vlans on these switches and managing these Vlans via VTP is perfectly Ok. You will need to route between these Vlans using the 3550. Make sure you have the EMI image for routing support and enable ip routing on the switch.
Make sure you read these documents:
Configuring Vlans:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.2_25_see/configuration/guide/swvlan.html
Configuring VTP:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.2_25_see/configuration/guide/swvtp.html
Configuring Routing:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.2_25_see/configuration/guide/swiprout.html
You don't need a dynamic routing protocol on the 3550 to route between Vlans. Default ip routing will take care of routing between its connected Vlans.
HTH,
__
Edison.
