Damage 7960/ 7940 hand set cable
Jan 9th, 2008
Hi, some hand set cable at 7940, 7960 disappared or have been stolen by someone. I need to get replacement cable, Is Cisco selling this cable part number (72-1792-01 rev.a0*)? Or can get similar cable from 3rd party appliance shop. Note: the cable has rj11 connector at a and b end.
Au Ray
Singapore
Rob Huffman Wed, 01/09/2008 - 19:52
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Au Ray,
Hope things are going well with you!
These are the best that I have found (and reasonably cheap). They are available in standard 12 or longer 25 foot models :)
http://www.thetelecomspot.com/cisco-voip-cisco-spare-parts-c-63_163.html?zenid=1b2468ae8ee6804d5590a1296aa8eff6
Hope this helps!
Rob
Please remember to rate helpful posts.....
auraycats Wed, 01/09/2008 - 19:59
tks Rob, I will check with the 3rd party vendor.
