Port Redirection with limited Public IP
Jan 9th, 2008
Hi need expert help, can Cisco pix 515 translate a single public ip to multiple internal IP? I need to redirect let us say smtp traffic to one private ip and http traffic to another private ip listening from the same public ip. Can this be done? Is there any configuration examples I could follow? Thanks
Overall Rating: 5 (1 ratings)
gfullage Wed, 01/09/2008 - 20:33
Sure can. Assuming you have that single public IP configured on the PIX's outside interface, do the following:
static (inside,outside) tcp interface 25 25 netmask
static (inside,outside) tcp interface 80 80 netmask
access-list inbound permit tcp any interface outside eq 25
access-list inbound permit tcp any interface outside eq 80
access-group inbound in interface outside
Any traffic coming in on TCP/25 for the outside IP address of the PIX will be forwarded internally to on port 25. Any traffic for port 80 will be forwarded to
jordielau Mon, 06/23/2008 - 22:35
hope you can help me ,i config my pix 515e following yours,but i still cann't access the web server.following is my configuration:
PIX Version 7.2(1)
hostname wanshitong
domain-name wanshitong.com
enable password vda4u.Aio7ssMh5X encrypted
interface Ethernet0
nameif outside
security-level 0
ip address 218.xx.xx.26
interface Ethernet1
nameif inside
security-level 100
ip address
passwd vda4u.Aio7ssMh5X encrypted
boot system flash:/image.bin
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit intra-interface
access-list 100 extended permit tcp any interface outside eq www
access-list 100 extended permit ip any any
access-list 101 extended permit ip any any
pager lines 24
logging enable
logging asdm errors
mtu outside 1500
mtu inside 1500
no failover
monitor-interface outside
monitor-interface inside
asdm image flash:/asdm521.bin
asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1
nat (inside) 1
nat (inside) 1
nat (inside) 1
static (inside,outside) tcp interface www www netmask
access-group 100 in interface outside
access-group 101 in interface inside
route outside 218.xx.xx.254 1
route inside 1
route inside 1
route inside 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
username cisco password 3USUcOPFUiMCO4Jk encrypted
http server enable
http outside
http inside
http inside
http inside
http inside
no snmp-server location
no snmp-server contact
snmp-server community public
snmp-server enable traps snmp authentication linkup linkdown coldstart
no sysopt connection permit-vpn
telnet outside
telnet inside
telnet inside
telnet inside
telnet inside
telnet timeout 5
ssh outside
ssh timeout 60
ssh version 1
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect http
inspect ftp
inspect dns
inspect icmp
inspect icmp error
inspect tftp
inspect esmtp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect sip
inspect sqlnet
inspect sunrpc
inspect xdmcp
policy-map type inspect dns migrated_dns_map_1
message-length maximum 512
service-policy global_policy global
tftp-server inside pix721
prompt hostname context
: end
nomair_83 Mon, 06/30/2008 - 04:56
just telnet to "interface ip" 80 from outside
and check the acl hits and logs.
