Registering IP Phone Over the Internet
Jan 9th, 2008
Is it possible to register a SIP load IP Phone on CCM over the Internet. I am looking at using CCM 5.X alongwith SBCs
Overall Rating: 5 (1 ratings)
Brandon Buffin Thu, 01/10/2008 - 05:33
Yes, assuming you have the correct ports open. In my opinion, it's much safer to use a VPN tunnel rather than opening up your CCM to internet traffic.
Hope this helps. If so, please rate the post.
Brandon
ananddiwakar Thu, 01/10/2008 - 09:43
Thanks a lot Brandon. Its true that there is a risk in opening CCM to the Internet, but some of our users want to have office extensions at home (and they are not okay with communicator >_< ). So I am checking out if this is possible. We are already running this for asterisk based phones.
Just wondering if you have any documents on how to do this with relevant information
Brandon Buffin Thu, 01/10/2008 - 12:32
One option is to deploy an 851/871 type router that will VPN back to the HQ. This would allow you to use a hard phone as opposed to IPC at these locations. If you need to register the phone over the internet you will need the SIP/Secure SIP ports (5060/5061) as well as the dynamic RTP ports open. Take a look at the following document.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/port/6_0/60plrev1.pdf
Brandon
