Ceritification Arrival
Jan 9th, 2008
Hi all,
I got a small query but its very important now.
One of my friend had pass CCNA examination in Oct'07, and till now he didnt received certificate. He got only ID given by Cisco,
1.How I can solve his problem?
2.In what way, I can take benefit of using Cisco ID.
Thanking you,
Overall Rating: 5 (1 ratings)
mounir.mohamed Fri, 01/11/2008 - 01:09
Ceritification Kit arrived withing 6 weeks maximum, and i recommend to go through the below steps to receive your cert kit.
1-Go to the below URL and use your Cisco ID as a login ID and if you do not know the password just press forget the password and they will send it to your e-mail which provided from your testing Center, If Yes go to step#2 if not make sure your address provided correct and confirm it.
Then cehck if your Certificate Kit status (it should be Send/Emailed/Shiped) something like that.
2-Go to Cisco Cert support and inform them about your issue and they will get back to you withing 2 business days.
*Pls rate helpful posts.
Best Regards,
Mounir Mohamed
