conditional load-balancing
Jan 10th, 2008
I need to load-balance traffic to serverfarm through VIP 0.0.0.0/0 TCP 80, including fragments associated with this traffic.
All the traffic that doesn't match the VIP should be routed.
I've configured the following VIP:
vserver PROXY2_PLS_80
virtual 0.0.0.0 0.0.0.0 tcp www
vlan 921
serverfarm PROXY_WAP2_PLES
sticky 15 group 30
replicate csrp sticky
replicate csrp connection
no persistent rebalance
inservice
May I assume that traffic that doesn't match the VIP will be routed?
Thanks for your help
Francois
Gilles Dufour Thu, 01/10/2008 - 06:07
the csm does not route by default.
You need to use the following config to make it route.
serverfarm route
no nat client
no nat server
predictor route
vserver route
virtual 0.0.0.0/0
serverfarm route
no persist rebala
inservice
Gilles.
francoisemo Thu, 01/10/2008 - 06:37
May I assume that the serverfarm "route" and vserver "route" must be configure in addition of the serverfarm "PROXY_WAP2_PLES" and vserver "PROXY2_PLS_80"?
And furthermore, may I assume that by default the fragmented packets will be correctly forwarded either to the serverfarm "PROXY2_PLS_80" or to the serverfarm "route" according to the traffic flow they belong to?
Thanks for you reply
