GLBP return traffic behavior
Jan 10th, 2008
Hi all,
Please take a look at the Figure 9. GLBP Deployment, Small Remote Site.
http://www.cisco.com/en/US/partner/products/ps6550/prod_presentation0900aecd801790a3.html
Assuming that the server is located behind the 10.44.11.0/30 and 10.44.12.0/30. The server of course has a route back to users 10.44.1.0 and 10.44.2.0.
Scully to Server is 4mb and Lonegunman to Server is 2mb.
Routing protocol from Scully and Lonegunman to the server is OSPF.
Load balancing will be done using "weight".
What i want to make sure is, if GLBP decides to use the 2mb link, i want to make sure that the route back or the return traffic will also use the 2mb link without tweaking my ospf current configuration.
Any suggestion?
