How to Measure the ring delai
Jan 10th, 2008
Hello everyone,
I have an SLA to respect with my contact center. I need to measure the time between the beginning of a phone call ringing on a agent's phone until the agent picks up the phone.
So I need the ring delai for each call.
Do you know how can I do that ?
simonandorfi Thu, 01/10/2008 - 06:10
what type / deployment of ContactCenter do you describe? UCCE / UCCX.
For both versions you may have a look in the database Schema PDF for your searched value ..
Simon
Abdulbaseer Mohammed Fri, 01/18/2008 - 19:53
  • Silver, 250 points or more
In your report tool you may want to run report on agents that will give your average answer time.
hope it helps.
Baseer.
osindero Sat, 01/19/2008 - 20:49
Check/run the stored procedure assoicated with the agent summary. It generates average speed to answer per agent. And I think you can equally generate average speed to answer per CSQ using the stored procedure for CSQ Activity.
You might want to go through the historical report administrator and devloper guide
