long Attributs
shrikar.dange Thu, 01/10/2008 - 02:52
  • Bronze, 100 points or more
the LONG attributes have many things included!!!
1st internal and external matching:
When you use match keword with redistribution you can ask the router to redistribute the internal and external type 1 and type 2 (of ospf in this case)to redistribute in to another routing protocol doamin.
2nd:
The 1 1 1 1 1 metric is used under eigrp for BW Dealay load etc parameters.If you configured the redisribution with these values the metric will be very low.
Under ospf metric can not be 1 1 1 1 1.
It should be only one number the cost.
Such attributes help you to have control over redistribution.
HTH,
regards,
shri :)
Jon Marshall Thu, 01/10/2008 - 02:56
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Ali
This is redistributing OSPF routes, both internal and external type 1 and external type 2 into IGRP/EIGRP.
The 1 1 1 1 1 are needed because IGRP/EIGRP use 5 separate values for their metric.
Jon
