Location appliance slow update?
Jan 10th, 2008
Guru's,
We have a client who is using WLC, WCS and a location appliance.
With normal setup, it takes the location appliance half an hour to show actual movement, that is, half an hour later.
When aggressive load balancing is enabled, things speed up to several minutes.
But since this is also a voice WLAN, aggressive load balancing is not recommended.
Who has experience with this setup?
gmarogi Wed, 01/16/2008 - 12:09
  • Bronze, 100 points or more
Yes. Aggressive load balancing is not a recommended option with Voice WLANs. Donot enable that. Disable that. The reason should be some other one. Just send me more details like configuration setup, diagram and debugs regarding your setup. I will go through them and let yu know what is the problem there.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
