AAA policy help
Jan 10th, 2008
Hi All
user1 >>>GroupA & user2 >>>GroupB
Router1 >>>NDG-A & Router2 >>>NDG-B
Now,
GroupA user must have "sh run" permission on NDG-A but not on NDG-B.
GroupB user must have "sh run" permission on NDG-B but not on NDG-A.
I created two shell command authorisation set and mapped it to GroupA & GroupB. Then inside the Group, I mapped the Shell command set to NDG. Here I have two associations.
(**I have tested with single association and its working. But not not with two)
But somehow its not working.
Please help.
Bharat
Overall Rating: 3 (1 ratings)
Jagdeep Gambhir Thu, 01/10/2008 - 06:20
  • Red, 2250 points or more
Bharat,
You need to set up Assign a Shell Command Authorization Set on a per Network Device Group Basis
In GroupA---> Assign a Shell Command Authorization Set on a per Network Device Group Basis---->
Add NDG A<====> Allow show run set**
Add NDG B<====> Deny all***
In Group B----->Assign a Shell Command Authorization Set on a per Network Device Group Basis---->
Add NDG B<====> Allow show run **
ADD NDG A<====> Deny all***
** Command autho set allowing Only show run
*** Command author set that deny's every thing.
Please check this link,
http://cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a00808d9138.shtml
Hope that helps !
~JG
Do rate helpful posts
Bharat Negi Thu, 01/10/2008 - 06:47
Hi Thanks for your reply. But this thing I have already done on ACS.
After intorducing following commands on Router, it worked.
aaa authorization commands 1 default tacacs+ local
aaa authorization commands 2 default tacacs+ local
aaa authorization commands 3 default tacacs+ local
aaa authorization commands 4 default tacacs+ local
aaa authorization commands 5 default tacacs+ local
aaa authorization commands 6 default tacacs+ local
aaa authorization commands 7 default tacacs+ local
aaa authorization commands 8 default tacacs+ local
aaa authorization commands 9 default tacacs+ local
aaa authorization commands 10 default tacacs+ local
aaa authorization commands 11 default tacacs+ local
aaa authorization commands 12 default tacacs+ local
aaa authorization commands 13 default tacacs+ local
aaa authorization commands 14 default tacacs+ local
aaa authorization commands 15 default tacacs+ local
Thanks for your help
Bharat
Jagdeep Gambhir Fri, 01/11/2008 - 06:23
We need to have these commands on the router. You never mentioned it in your orignal post.
Anyways , there is no need to put 15 line on the router. Just three will take care
i.e.
aaa authorization commands 0 default tacacs+ local
No need to count from 1 to 15.
~JG
