Listing / Removing clients from "Client Exclusion Policies"
Answered Question
Jan 10th, 2008
Hello.
Due to "Excessive 802.11 Association Failures" and "Excessive 802.11 Authentication Failures", I have some users that cannot connect anymore to the WLC system.
Is there a list of these "excluded" clients ??
How can I remove one of these "excluded" clients from that list??, i.e. un-exclude them
Thanks.
Correct Answer by milan_simcik about 9 years 2 months ago
Hi Marcelo,
in WCS menu Monitor-clients click on new search (left tab) and choose from drop-down menu (All exluded Client). List of excluded clients will occure. If you click to a given excluded client you can from drop-down menu remove that client from exclusin list.
Overall Rating: 4.5 (2 ratings)
Rob Huffman Thu, 01/10/2008 - 05:30
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Marcelo,
Exclusion List (Blacklist) Client Feature
If a client is not able to connect to an access point, and the security policy for the WLAN and client are correct, the client has probably been disabled. In the controller GUI, you can view the client's status on the Monitor > Summary page under Client Summary. If the client is disabled, click Remove to clear the disabled state for that client. The client automatically comes back and, if necessary, reattempts authentication.
Hope this helps!
Rob
maraboli Thu, 01/10/2008 - 06:13
Hi Rob
Thanks for the pointer, I was looking for these options under the WCS, not the Controller itself.
This should be available in WCS as well, right ? (if not, what's the point in having a WCS?)
These things are not mentioned in the "online HELP".
Thanks for your response and time.
best regards,
Correct Answer
milan_simcik Mon, 02/11/2008 - 00:51
Hi Marcelo,
weymannpe Mon, 06/02/2008 - 23:29
Hi all,
I'm using WCS version 5.0.56.0.
I can see an entry under "Monitor" security tab, so i can remove the client (so far so good).
But if I use the search as Marcelo described, I never get an entry.
Does anyone of you have the same problem?
Did I make something wrong?
Thanks!
Best regards,
Peter
Trending Topics - Security & Network
