moving config
Jan 10th, 2008
i just purchased another PIX 506e to replace the old one i have! I have copied the config from that OLD pix to a TFTP server. Now how do i write that config to the new pix506E?
ajagadee Thu, 01/10/2008 - 07:04
pixfirewall(config)# tftp-server
pixfirewall(config)# config net :
Please refer the below URL for details:
configure net
The configure net command merges the current running configuration with a TFTP configuration stored at the IP address you specify and from the file you name. If you specify both the IP address and path name in the tftp-server command, you can specify server_ip :filename as simply a colon ( : ).
For example:
configure net :
Danny Guillory Jr Thu, 01/10/2008 - 07:53
would anyone happen to know how to reset the pix to factory defaults, in the command line interface?
ajagadee Thu, 01/10/2008 - 08:16
For the PIX 501 and PIX 506/506E only:
configure factory-default [inside_ip_address [address_mask]]
factory-default - Specifies to clear the current configuration and regenerate the default, factory-loaded configuration. This command is supported for the PIX 501 and PIX 506/506E only in PIX Firewall software Version 6.2.
Please refer the URL I had posted earlier for details.
Danny Guillory Jr Thu, 01/10/2008 - 09:38
when uploading the cisco config to then new PIX506E i iam getting this:
tftp: Timed out during transfer
any ideas?
