ASA to Linksys VPN help
Jan 10th, 2008
I am trying to configure site to site vpn tunnels with linksys routers. The linksys routers pick up IP addresses via DHCP. I tried to configure a 0.0.0.0 tunnel group but when the vpn traffic tries to establish, it hits the DefaultRAGroup tunnel group. Has anyone had any experience with this??
Any help is appreciated!!
htarra Wed, 01/16/2008 - 13:43
  • Bronze, 100 points or more
I've seen the Linksys create several tunnels at once. It's a very persistent device. Try having the Linksys disable the IPSec connection. Then clear the SA's on the ASA. Then enable the tunnel on the Linksys. It should create just one tunnel.
