VRF lite
Answered Question
Jan 10th, 2008
When using VRF lites, does the packets leave de Router with labels? or the VRF are just locally significant?
regards...
Correct Answer by etienne.basset about 9 years 3 months ago
hello
yes they can, assuming the vrf(s) you want to make communicate use the same vlan on both router
Etienne
Overall Rating: 5 (2 ratings)
mohammedmahmoud Thu, 01/10/2008 - 07:18
  • Green, 3000 points or more
Hi Ricardo,
VRF-Lite does not include the Provider Edge MPLS functionality, more specifically MPLS label switching and MPLS control plane are not supported in the VRF-Lite implementation, and thus no labels.
BR,
Mohammed Mahmoud.
ccnp_seeker Thu, 01/10/2008 - 07:25
Thanks Mohammed for the answer...
So if I have a router that does not use vrf lite connected to a Router that use vrf lite, they can communicate?? (assuming that the correct routes are configured and so on)
regards...
Correct Answer
etienne.basset Thu, 01/10/2008 - 10:15
hello
Etienne
