Etherchannel load
Jan 10th, 2008
Can anybody tell me how to interpret the "load" column from the "show etherchannel port-channel" command? Is it a hex value? Here two examples:
Index Load Port EC state No of bits
1 11 Gi2/48 Active 2
2 22 Gi3/48 Active 2
0 44 Gi5/1 Active 2
3 88 Gi6/1 Active 2
1 55 Gi2/47 Active 4
0 AA Gi3/47 Active 4
Thanks in advance,
Stephan
andrew.burns Fri, 01/11/2008 - 06:37
  • Gold, 750 points or more
It's actually a binary representation of the distribution method. (Not sure how useful it is but there you go...)
For example, comparing 55 and AA we get:
01010101
10101010
Which is a simple alternation between the ports.
If we compare 11,22,44,88 we get:
00010001
00100010
01000100
10001000
Which again gives a simple alternation between the ports. I guess it may be useful in the case where you have an uneven distribution of ports (and hence an uneven distribution of traffic) - 3 ports gives you the following values: 0x49 0x92 0x24, which in binary is:
01001001
10010010
00100100
Which shows the 3:3:2 ratio of traffic distribution that you'd expect.
Andrew.
