PVC bandwidth issue
Jan 10th, 2008
Hello
I have several remote sites with frame relay connections back to a corporate site through two PVCs at each remote site(one goes directly to the corporate site, one routes through another secondary corporate site). I'm running QOS which is locking each PVC down to 256k mincir. I'd like to route our VOIP traffic over one PVC and data traffic over the other, however, I'd like the data PVC to burst above mincir. Is there a way to configure the PVC bandwidth separately? The current configuration locks both PVCs down to 256K. I tried cheating by configuring 512K mincir, but that resulted in occasional issues with choppy voice so I need to restrict this to actual cir, which is 256K. However, that really slows down one of our apps that needs to talk to a database at our corporate site. I'd like to configure a route map to push VOIP over S0.16 and data over S0.17 and let S0.17 burst above 256K.
Configuration on the remote router is as follows:
version 12.3
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname
logging buffered 4096 debugging
enable secret
enable password
memory-size iomem 25
clock timezone mst -7
ip subnet-zero
no ip domain lookup
class-map match-all voice-traffic
match access-group 150
policy-map voice-policy
class voice-traffic
priority 192
class class-default
fair-queue
interface FastEthernet0
ip address 172.20.129.254 255.255.255.0
speed auto
interface Serial0
description
no ip address
encapsulation frame-relay
no fair-queue
frame-relay class voice
frame-relay traffic-shaping
frame-relay ip rtp header-compression
interface Serial0.16 point-to-point
description
bandwidth 256
ip address 172.20.254.30 255.255.255.252
frame-relay interface-dlci 16
interface Serial0.17 point-to-point
description
bandwidth 256
ip address 172.20.253.30 255.255.255.252
frame-relay interface-dlci 17
router eigrp 100
variance 2
redistribute connected
network 172.20.253.28 0.0.0.3
network 172.20.254.28 0.0.0.3
distribute-list 10 in
no auto-summary
eigrp stub connected summary
no eigrp log-neighbor-changes
ip classless
no ip http server
map-class frame-relay voice
frame-relay cir 256000
frame-relay bc 2560
frame-relay be 0
frame-relay mincir 256000
service-policy output voice-policy
no logging trap
access-list 10 deny 172.20.0.0 0.0.255.255
access-list 10 permit any
access-list 150 permit udp any 10.1.4.0 0.0.3.255
line con 0
exec-timeout 0 0
password
login
line aux 0
line vty 0 4
password
login
no scheduler allocate
sntp server 172.20.254.29
end
Thanks for any help.
Kevin Dorrell Thu, 01/10/2008 - 08:34
If you put the frame-relay class on the sub-interfaces rather than the physical interface, then they will apply to the individual DLCIs. You can then have a different class on each subinterface.
In fact, I'm not sure your class mapping is working at all. I thought that putting it on the physical interface would apply it only to those DLCIs that are coming through the physical interface.
If I am wrong on that last point, someone please put me right?
Kevin Dorrell
Luxembourg
In order to confirm that applying this to the physical interface is working you would need to really have specific traffic monitoring of the innterface and DLCI's to get some indication of what the PVC's were doing.
A sample would be as below, with a different map-class meeting the requirements per PVC.
ip address 10.21.110.18 255.255.255.252
ip accounting output-packets
bandwidth 64
class PQ256_128K
map-class frame-relay PQ256_128K
frame-relay bc 32000
frame-relay mincir 128000
frame-relay priority-group 1
bsternfield Fri, 01/11/2008 - 20:21
The class map is definitely working--I can detect the speed difference with the map applied and removed. I'll try applying the map to the individual DLCIs. If I do that, I assume I can omit the frame-relay traffic-shaping and ip rtp header compression statements on the physical interface?
