Warning message
CDBLException Dump: [Object creation failed] Administration
Jan 10th, 2008
This error is found in the main admin page of the Cisco Callmanager . Im not able to add phones. Cant start the CallManager service either in the servicability page it says error 1547. Pls help need immediate help.
Thanks in advance.
Overall Rating: 3 (1 ratings)
Rajesh Revuru Thu, 01/10/2008 - 08:38
  • Silver, 250 points or more
The error means that there is SQL replication issues between Subscriber and Publisher.
On your publisher, can you run DBHelper.exe and select re-initialize to sync the databases.
Rajesh Revuru Thu, 01/10/2008 - 08:51
It should be under C:/Program Files/Cisco/Bin, or just search, btw what version of call manager are you running?
Ayodeji Okanlawon Thu, 01/10/2008 - 09:39
  • Cisco Designated VIP,
    2017 IP Telephony
Please note that you may not have this tool. It does not neccesarily ship with callmanager. Sometimes you are reffered to TAC to get this tool.
I am sure someone here on the forum can send the tool to you.
One other thing you need to do is this, you need to run admin utility tool to check password sycnronisation on your cluster.
Admin utility is in the same folder as DBLhelper
