Time display on 7940/7960 IP phones
cpubob Thu, 01/10/2008 - 08:48
  • Bronze, 100 points or more
If you have a local ntp server then you don't need to do anything, they will recieve the ntp broadcast as long as you server is sending it to the local network. For a remote server, check this doc out, it tells you which parameters to change and the behaviour for each.
For my setup, I just configured ASTERISK to sync off my router and then ASTERISK provided clock to the phones.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7960g_7940g/sip/2_0/english/administration/guide/maintain.html#wp1042639
