VPN tunnel creation 506e
Jan 10th, 2008
I have a remote location that VPNs into a main site through a DSL internet conection to a 506e pix firewall. One workstation currently establishes a VPN and only they(workstation that initiated connection) can access resources. I would like to create a VPN tunnel that 3 workstations and a polycom video conferencing unit can go through to get to our main locations network and that no users have to manually initiate. I would like to utilize the latest tecnology in VPNs, would that be SSL? It would have to be compatible with my current 506e firewall. Would I get another 506 firewall and create tunnel between the two? would they then access internet through the same gateway that our main location uses? Any help would be appreciated, as you can tell I am just getting my feet wet.
RHCI2232228 Thu, 01/17/2008 - 06:07
Thank you, I appreciate it. I will follow the link and prepare for the installation.
