MAC ACCESS-LIST on Ethernet Switching Network Modules
Jan 10th, 2008
  • Bronze, 100 points or more
I've read at Cisco.com that Ethernet switching network modules can't support Secure ports (at http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00801d2d60.html#wp1043334 ).
Do you know if the new NME-XD-48ES-2S-P will support (and mac access-lists - 700-799 48bit Mac-address-access-list), on 3825 Series?
Thanks for your help,
Met
Edison Ortiz Fri, 01/11/2008 - 13:47
  • Hall of Fame,
    Founding Member
That module has the same characteristics are the previous modules with the exception that it provides PoE and has (2) small SFPs.
As for the MAC Access ACLs (700-799), that's an IOS feature incorporated in all routers.
HTH,
__
Edison.
metalium2007 Fri, 01/11/2008 - 13:50
with the previous modules on 3725 series it wasnt possible to make secure ports and mac acls......
