ME3400 configuration
Jan 10th, 2008
we need to temporary setup the ME3400 switch to interconnect the two sites. Could somebody tell me how to configure the ME3400 based on the attached network diagram. I only have one unit of the ME3400 switch loan from cisco.
william.caban Fri, 01/11/2008 - 03:37
system mtu 1546 ! Max for FE Interfaces
vlan dot1q tag native ! recommended for security
errdisable recovery cause l2ptguard ! if thresholds are set
interface
switchport access vlan
switchport mode dot1q-tunnel
l2protocol-tunnel
l2protocol-tunnel shutdown-threshold ! recomended for protection
l2protocol-tunnel drop-threshold !recommended for protection
Finally, if you set any of the port as Dot1q you must change the interface-type. This new in the ME series.
More details and configuration options are available at "Cisco ME 3400 Switch Software Configuration Guide"
http://www.cisco.com/univercd/cc/td/doc/product/metro/me3400/12244se/scg/index.htm
-W
