Advantages of using a seperate controller for guest access?
Jan 10th, 2008
Can someone give me a good reason to use a seperate controller in a DMZ for guest users versus just trunking a DMZ VLAN to the controller. Certainly it makes sense to have a guest controller when you DMZ is not accessable to the controller locations (or you have a bunch of remote locations, but only one internet connection), but in the event that the controllers are located in a place that it can hit the DMZ is there a good reason to use a guest controller.
SHANNON WYATT Thu, 01/10/2008 - 14:55
I'm not even sure if that is a good reason. You can alway trunk to another non-routed VLAN and stick a cable modem and firewall to give guest user access. I'm working with someone now that thinks this is the way to go, but I've got to add a 4402-12, a switch (need GB connectivity for the controller) at a minimum. Again, it would make perfect sense if the location of the internet was not in the same building.
Trending Topics - Security & Network
