Correct cable for
Jan 10th, 2008
Hello Experts!
I am looking for the cable and baud rate for connecting to WS-SUP32-10GE-3B module. On the Cisco website (http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Chassis_Installation/Cat6500/03instal.pdf) it says that sup module for 6513 uses a rollover cable at 9600 8 none 1. However,this did not work with my current sup32 module. Does anyone have a suggestion?
Thanx
keegan.holley Thu, 01/10/2008 - 17:31
Computers usually have a DB-9 serial port are you sure the adapter you are using has the correct pinouts. If you have any doubts the standard one piece console cable used for other cisco devices should work.
MARLIE JOSEPH Thu, 01/10/2008 - 17:34
Thanks for your input. Issue was the standard one piece console cable was bad. I replaced it with a db9 connector and rollover cable and was able to connect.
