CME/CUE - Got external missed calls, and when i dial back...
Jan 10th, 2008
Hi Pros,
System: CME Router 2811 3.3+CUE Module 2.2 + 2Cards FXO(4ports each)
On my cisco ip-phone , i got external missed calls and when i select one of these external calls, and press DIAL to call back... it doesnt work. i do know its because there is no 9 just before...
so how can i set my system to place the 9 before for these calls?
Overall Rating: 5 (2 ratings)
Brandon Buffin Thu, 01/10/2008 - 13:10
You can use a voice translation rule such as:
voice translation-rule 91
rule 1 // /91/
voice translation-profile 1
translate calling 91
voice-port 0/0
translation-profile incoming 1
Hope this helps. If so, please rate the post.
Brandon
fxavier.cat Thu, 01/10/2008 - 14:55
thanks for your help Brandon
how can i add another rule to just put a 9 for local call ? my local calls are 514-xxx-xxxx
because with the 91 rule, i got a message from my provider..."not necessary to use 1 blabla"
thanks in advance
Brandon Buffin Fri, 01/11/2008 - 05:38
You could modify the translation rule as follows:
voice translation-rule 1
rule 1 /^514/ /9/
rule 2 // /91/
translate calling 1
voice-port 0/0
Brandon
anwar-ahmed Thu, 10/30/2008 - 11:19
Is there any possibility to use common rule for all incoming area code including long distance.
Thanks in advance
Brandon Buffin Thu, 10/30/2008 - 11:55
The only way to use one rule is if all calls get the same prefix. This is usually not the case. Local calls may only get 9 while long distance get 91.
Hope this helps.
Brandon
jwaters24 Fri, 06/20/2008 - 05:39
I added the the voice translation rules listed in the thread, but still unsuccessful.
Any suggestions?
