CCNA - which test should I take?
Jan 10th, 2008
Just before the test changed in November, I opted for the 2-exam track for the CCNA and passed my INTRO 640-821 with flying colors. I then studied for and took my ICND 640-811 but fell short with a 772.
Cisco says I can now be CCNA certified by passing the new ICND2, but I'm wondering if I should just study the new material and sit for the whole 640-802 CCNA exam since I obviously know the earlier material better and this would be roughly half the test.
Any suggestions?
Overall Rating: 4 (1 ratings)
Danilo Dy Fri, 01/11/2008 - 04:03
Since you already passed INTRO last year, you can now become CCNA by passing 640-816 ICND2
However, you can also become CCNA by passing 640-802 CCNA
Now it depends on you which one you should take. If you think you are more prepared to tackle 640-802 CCNA and you feel more confident that you will pass it, then go for it. Otherwise, take 640-816 ICND2
Dandy
anghesomt Sun, 01/20/2008 - 19:33
I would recommend you to break the exam; just take the ICND 2 only. Taking the entire exam is a rescue bussiness and you can never be absolutely sure in CCNA b/c the exam is all about core concepts and real-worls apps.
Good luck
