Open port 3389
fullerthaler
How do I open port 3389?
This is what I typed in, but it didn't work.
static (inside,outside) tcp x.x.x.x 3389 192.168.3.2 3389 netmask 55.255.255.255
access-list outside_in permit tcp host any host x.x.x.x eq 3389”
I don't know what to use for the access-list. I do not have a "outside_in" access list set up. These are the only access lists I have:
access-list tehama-vpn permit ip 192.168.0.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list nonat permit ip 192.168.0.0 255.255.255.0 192.168.3.0 255.255.255.0
acomiskey
Level 10
Level 10
Is x.x.x.x also the outside interface ip?
If so then it needs to be...
static (inside,outside) tcp interface 3389 192.168.3.2 3389 netmask 255.255.255.255
access-list outside_in permit tcp any host x.x.x.x eq 3389
access-group outside_in in interface outside
Here is my config file. What should I change?
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xx encrypted
passwd xx encrypted
hostname fm-fw
domain-name sfcc.org
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list outside_in permit tcp host 1.2.3.4 host 7.7.7.7 eq 3389
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 7.7.7.7 255.255.255.252
ip address inside 192.168.0.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list nonat
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp 7.7.7.7 3389 192.168.3.2 3389 netmask 255.255.255.255 0 0
route outside 0.0.0.0 0.0.0.0 74.93.9.14 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
http 192.168.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
sysopt ipsec pl-compatible
crypto ipsec transform-set sfccset esp-des esp-md5-hmac
crypto ipsec transform-set sfccaesset esp-aes-256 esp-md5-hmac
crypto dynamic-map sfccdmap 20 set transform-set sfccaesset
crypto map sfccmap 10 ipsec-isakmp
crypto map sfccmap 10 match address tehama-vpn
crypto map sfccmap 10 set peer 1.1.1.1
crypto map sfccmap 10 set transform-set sfccaesset
crypto map sfccmap interface outside
crypto map dyn-map 20 ipsec-isakmp dynamic sfccdmap
isakmp enable outside
isakmp key ******** address 0.0.0.0 netmask 0.0.0.0
isakmp key ******** address 1.1.1.1 netmask 255.255.255.255
isakmp identity address
isakmp nat-traversal 20
isakmp policy 5 authentication pre-share
isakmp policy 5 encryption aes-256
isakmp policy 5 hash sha
isakmp policy 5 group 1
isakmp policy 5 lifetime 86400
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 1
isakmp policy 10 lifetime 1000
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 60
ssh 1.1.1.1 255.255.255.255 outside
ssh 0.0.0.0 0.0.0.0 outside
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 60
console timeout 0
dhcpd ping_timeout 750
username daved password xxxx
privilege 15
terminal width 80
Change...
to
static (inside,outside) tcp interface 3389 192.168.3.2 3389 netmask 255.255.255.255 0 0
