Unity 4.X - Call transfer to "0"
Tommer Catlin Thu, 01/10/2008 - 14:52
  • Green, 3000 points or more
For the subscriber you have a known problem, log into Unity SA
Pull up the subscriber
click on Caller Input
See where Caller Input 0 is going to
Typically, it is going to the "Operator" call handler. This would a transfer rule.
Open up the Operator CallHandler
Click on Transfer
Look to see what extension the Operator is at. If there is no number, then this is why.
Make sense?
ranpierce Thu, 01/10/2008 - 14:56
  • Silver, 250 points or more
when press 0 it is going to the operator call handler. it sounds like it is working normal. pressing 0 and no one answers.
Check to see what the call transfer settings are
ranpierce Fri, 01/11/2008 - 06:28
If you send calls directly to the operators greeting that is expected behavior. That is the system greeting you hear I think.
You need to give the operator an extension. Or have it transfer to a subscriber extension, or record a greeting.
