Jon Marshall Thu, 01/10/2008 - 14:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Jerry
You will probably need to setup site-to-site/L2L tunnels between your sites. You will need to check whether
1) your routers that connect the sites support IPSEC vpn tunnels - there will probably be an IOS that does.
2) Your routers have enough horsepower and memory to add the additional overhead of IPSEC.
Once you have sorted this out here is a link to some configuration examples for site-to-site IPSEC tunnels between routers.
http://www.cisco.com/en/US/tech/tk583/tk372/tech_configuration_examples_list.html#anchor17
Jon
