RME ssh config fetch fails
Answered Question
Jan 10th, 2008
Hi all,
I recently had to import 1600 devices into LMS2.6 for a new customer. ssh only is allowed. I can ssh fine from the CW server desktop using the supplied credentials. However, the ssh mgt station to device test fails straight away. SNMP is good.
Sniffing gives bad checksum result.
RME transport settings are telnet / ssh for all.
Anyone?
thanks,
Marty.
Correct Answer by Joe Clarke about 9 years 1 week ago
You will need to enable ArchiveMgmt Service debugging and get the dcmaservice.log after reproducing the problem then.
Overall Rating: 0 (2 ratings)
martyyates Thu, 01/10/2008 - 17:20
Hi Joe,
Resource Manager Essentials 4.0.6 - patched on 18 Dec 2007.
Joe Clarke Thu, 01/10/2008 - 17:28
When was it downloaded? The first post had a bug in it where SSH would fail due to timeout. The image posted now has the fix.
martyyates Thu, 01/10/2008 - 17:45
Hi again,
I am running your patch Joe. Saw the previous post that resulted in the bug fix etc.
Applications and Packages installed with Resource Manager Essentials
Patches installed
Patch Name Version Install Date
No records.
Back to Top
Applications installed
Application Installed Version Installed Date
Bug Toolkit 4.0.6 18 Dec 2007, 15:25:11 NZDT
Network show Commands 4.0.6 18 Dec 2007, 15:25:15 NZDT
NetConfig Application 4.0.6 18 Dec 2007, 15:25:14 NZDT
JRM Adapter 4.0.6 18 Dec 2007, 15:25:14 NZDT
Inventory Reports 4.0.6 18 Dec 2007, 15:25:14 NZDT
SWIM repository 4.0.6 18 Dec 2007, 15:25:15 NZDT
Device Management 4.0.6 18 Dec 2007, 15:25:13 NZDT
Config Management Module 4.0.6 18 Dec 2007, 15:25:12 NZDT
Software Image Management Service 4.0.6 18 Dec 2007, 15:25:17 NZDT
Maker Checker Services 4.0.6 18 Dec 2007, 15:25:14 NZDT
Inventory Data Extraction 4.0.6 18 Dec 2007, 15:25:14 NZDT
Syslog Analyzer 4.0.6 18 Dec 2007, 15:25:17 NZDT
Syslog Collector 4.0.6 18 Dec 2007, 15:25:17 NZDT
Config Editor Application 4.0.6 18 Dec 2007, 15:25:11 NZDT
Change Audit Services 4.0.6 18 Dec 2007, 15:25:11 NZDT
Inventory Poller Functionality 4.0.6 18 Dec 2007, 15:25:13 NZDT
CCO Tools 4.0.6 18 Dec 2007, 15:25:12 NZDT
Back to Top
Packages installed
Packages Installed Version With Patch Level Installed Date
Common Config Job Services 4.0.6 18 Dec 2007, 15:25:11 NZDT
Object Grouping Service 4.0.6 18 Dec 2007, 15:25:13 NZDT
Utility API 4.0.6 18 Dec 2007, 15:25:17 NZDT
Common Incremental Device Support 4.0.6 18 Dec 2007, 15:25:15 NZDT
Inventory Collector Services 4.0.6 18 Dec 2007, 15:25:13 NZDT
Common Reporting Infrastructure 4.0.6 18 Dec 2007, 15:25:12 NZDT
Essentials Database 4.0.6 18 Dec 2007, 15:25:16 NZDT
Framework of Common Syslog Service 4.0.6 18 Dec 2007, 15:25:13 NZDT
CLI Data Extraction RME 4.0.6 18 Dec 2007, 15:25:12 NZDT
Common Command Line Framework 4.0.6 18 Dec 2007, 15:25:11 NZDT
RME Common Functionality 4.0.6 18 Dec 2007, 15:25:15 NZDT
User Interface Infrastructure 4.0.6 18 Dec 2007, 15:25:17 NZDT
Resource Manager Essentials Help 4.0.6 18 Dec 2007, 15:25:16 NZDT
Performance Tunning Tool 4.0.6 18 Dec 2007, 15:25:16 NZDT
Resource Manager Essentials 4.0.6 18 Dec 2007, 15:25:16 NZDT
Miscellaneous Functionalities 4.0.6 18 Dec 2007, 15:25:14 NZDT
Common CLI Framework 4.0.6 18 Dec 2007, 15:25:12 NZDT
Correct Answer
Joe Clarke Thu, 01/10/2008 - 21:28
martyyates Sun, 01/13/2008 - 20:02
Hi Joe,
looks as though my bulk import was incorrectly done. Re-ran it with tacacs enable in addition to the existing telnet user. Configs were then archived fine. Thanks for your time. ssh confirmed as in attached log.
- Marty.
