SIP PHONES ON Cisco Unified CallManager Express 4.0(2)
Paolo Bevilacqua Thu, 01/10/2008 - 16:32
Hola Walter.
Any sip phone should work with cme, howver it's not officially supported by cisco so if it doesn;t work you are on you own.
This is also the reason why there is no guide except thatn for cisco phones.
However just configure the voice register pool with mac address is the hone is local, or username/password if remote.
HI Bevilacqua
Thank very much for answering, I configured the following parameters on the callmanager express 4.0 for the SIP PHONE D-LINK DHP-140S.
voice register global
mode cme
source-address 192.168.1.20 port 5060
max-dn 144
max-pool 36
authenticate realm user1
voice register dn 17
number 8670
voice register pool 17
id mac 0013.46C9.A7BB
number 1 dn 17
max registrations 36
dtmf-relay rtp-nte
username user1 password user1
I forced the SIP PHONES for registered to sip server which is callmanager express ip 192.168.1.20.
You can check on the following capture.
Any help will be appreciated.
Regards.
Walter Flores
Paolo Bevilacqua Thu, 01/17/2008 - 09:17
if the phone is local on CME lan, you do not need username an password. If it is remote, please configure username to be the same as number assigned, and mac address can be all zeroes.
