Identifying ASA traffic types and individual bandwidth utilization
Overall Rating: 0 (1 ratings)
srue Thu, 01/10/2008 - 17:27
  • Blue, 1500 points or more
a sniffer is going to be the best way to do this. try wireshark (formerly known as ethereal).
i'm not sure how much time you think putting a sniffer on the network takes, but in the time it took you to compose your original post and read this, you could nearly have one up and running.
cisco24x7 Thu, 01/10/2008 - 18:23
  • Silver, 250 points or more
wireshark on windows? I don't think wireshark
can do the job especially if you're talking
capture about 20GB of data.
The best thing to do, IMHO, is to run
tcpdump on gentoo linux or FreeBSD and dump
it into a file. This will allow you to replay
the data later from the same linux system
via ethereal/wireshark from X-windows.
Wireshark is ok for simple task but if you
think about capturing a lot of data for
replay, tcpdump is the way to go.
CCIE security
srue Thu, 01/10/2008 - 19:44
in that case you may as well use openbsd.
where did you get 20gb from anyway?
cisco24x7 Thu, 01/10/2008 - 19:56
in order to determine traffics type, you need
a lot of data. As a security guy, I would
think 20GB is not that much.
Guy's thank you for your prompt responses. I truly appreciate your help. Sniffers are great for looking that the different types of traffic but one of my requirements is bandwidth utilization for each protocol the sniffer would see.
I may be wishing upon a star because the tool that I need would visually display an overlay graph with bandwidth(s) displayed. Any ideas?
sbaddipu Fri, 01/11/2008 - 09:53
You need a device like a packeteer...
satya
acomiskey Fri, 01/11/2008 - 09:53
  • Green, 3000 points or more
ASDM 6 includes a dashboard which includes top sources/destination/services etc.
