WAAS Configuration with Inline card
Jan 10th, 2008
I have a 612 as the Center Manager and two 7341's, one in the datacenter and one at a remote location.
I have placed one 7341 inline between two NetApp 3070s and a Cisco 6500 switch. The other 7341 is inline between a NetApp R200 and another Cisco 6500.
First question, is this inline configuration correct? Can I go directly from the NetApp interface to the Inline card on the WAAS then to the switch or do I need an additional "network" device between the NetApp appliances and the switches?
The symptom is, when configured as described, if I put the SnapMirror traffic in passthrough mode, I have no problems. If I change this to any of the traffic options, TFO Only, TFO with LZ, TFO with DRE or Full Optimization, any existing SnapMirror sessions continue and optimization is experienced; however, no new SnapMirror sessions can start. I receive an error in the NetApp indicating that it "failed due to a network error".
If I change it back to passthrough, the sessions perform a retry and start successfully.
Is it my physical configuration, or is it something else?
Any ideas?
Thank you.
Don Zajic
[email protected]
Zach Seils Thu, 01/10/2008 - 18:58
  • Cisco Employee,
Don,
You don't necessarily need an intermediate network device, but I would like to understand your topology a little better. Can you provide a basic topology diagram of your setup?
In addition, what version of WAAS are you running?
Zach
donaldzajic Fri, 01/11/2008 - 13:37
Zack,
I am running 4.0.13.23 on all three devices. I will work on a diagram for you.
Don
Zach Seils Fri, 01/11/2008 - 23:18
  • Cisco Employee,
Don,
If traffic is passing through both inline groups in a single WAE, you may be running into CSCsk47177.
Zach
