NAC - How to troubleshooting network scanning not working
Jan 10th, 2008
I'm testing Cisco NAC agentless in-bound layer2 mode following the CAM manual:
•Configure the Quarantine Role
•Load Nessus Plugins into the Clean Access Manager Repository,
•Configure General Setup,
•Apply Plugins,
•Configure Plugin Options,
•Configure Vulnerability Handling,
•Test Scanning (I can successfully "test from Manager" from "test" tab)
I'm sure I disabled personal firewall on the testing client on untrusted vlan.
When I using a testing PC to open a browser to access internet, I was redirected to the authentication pape, after login, I got unlimited access. The problem is It looks CAS did not do any scan to the PC as expected according to the policy I defined for "unauthenticated" role, there is no any scan report poped up.
1.Any way I can check if Nessus Scanning is working properly on CAS?
2.Any log or evidence I can check to make sure the scanning start, in process, complete , so I can know the status.
3.How to check all plugin already pushed and sycronized by CAM?
Thanks in advance
