Bringing up a third interface - cannot ping servers
Jan 10th, 2008
Hi All,
I have a CSS 11503 that already had 2 interfaces up and running fine. The frontend is on vlan 26 and backend server vlan is on vlan 836. Now, I have some servers on vlan 301 that needed load balancing and brought up the third interface.
Here is my config
interface 1/1
bridge vlan 836
interface 1/2
bridge vlan 26
interface 2/1 (this is the new interface)
bridge vlan 301
circuit VLAN836
ip address 10.10.235.5 255.255.255.128
circuit VLAN26
ip address 10.10.26.5 255.255.255.0
circuit VLAN301
ip address 10.44.0.5 255.255.252.0
Here is the "show ip route" output
BCMDC-CSS1# sh ip route
prefix/length next hop if type proto age metric
10.1.20.0/22 10.1.22.150 2 mgmt local -- --
0.0.0.0/0 10.10.26.1 1022 remote static 5342983 0
10.44.0.0/22 10.44.0.5 1021 local local 7122 0
10.10.26.0/24 10.10.26.5 1022 local local 5343307 0
10.10.235.0/25 10.10.235.5 1023 local local 5343288 0
Show arp contains all the servers I want to ping and here is the arp table on the CSS
10.44.0.1 00-00-0c-07-ac-1f dynamic 2/1
10.44.0.2 00-d0-02-f3-a8-00 dynamic 2/1
10.44.0.3 00-09-12-ed-6f-00 dynamic 2/1
10.44.0.20 00-11-25-9d-e4-98 dynamic 2/1
10.44.0.21 00-11-25-9d-ee-d7 dynamic 2/1
10.44.0.30 00-11-25-9d-e6-86 dynamic 2/1
10.44.0.31 00-14-5e-3c-71-38 dynamic 2/1
10.44.0.32 00-11-25-4a-82-a1 dynamic 2/1
10.44.0.33 00-14-5e-3e-60-e1 dynamic 2/1
10.44.0.34 00-11-25-9e-e5-ce dynamic 2/1
10.44.0.35 00-11-25-9c-66-c9 dynamic 2/1
10.44.0.40 00-1a-64-4f-21-bc dynamic 2/1
10.44.0.41 00-1a-64-4f-23-6e dynamic 2/1
10.44.0.50 00-1a-64-4f-2f-74 dynamic 2/1
10.44.0.51 00-1a-64-4f-22-72 dynamic 2/1
10.44.0.60 00-1a-64-4f-1c-ba dynamic 2/1
10.44.0.61 00-1a-64-4f-13-06 dynamic 2/1
I cannot ping any of the 10.44.0.x address. The interface is up and it is connected to a 6509 switch as an accessport on vlan301 and it shows up and up.
There are no ACLs configured. I am just trying to ping the servers before I can write the content rules.
Any ideas?
mchockalingam Thu, 01/10/2008 - 20:14
OK. I figured out that I cannot ping the servers. But, I cannot ping the circuit vlan 301 IP from the router which is 10.44.0.5.
However, I can ping vlan 836 circuit IP like 10.10.235.5 Here is the ping result from the router where the css is connected to
gw1>ping 10.10.235.5
Sending 5, 100-byte ICMP Echos to 10.10.235.5, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
gw1>ping 10.44.0.5
Sending 5, 100-byte ICMP Echos to 10.44.0.5, timeout is 2 seconds:
Success rate is 0 percent (0/5)
