traceroute question
Guys,
Please take a look this question in CCIE written, what answer do you think is correct?
From what I understood before, A seemed to be the correct one; because source only sends UDP and destination only response with ICMP reply But after I did a lab test, it seems none of these are correct.
My answer is to add “permit udp and permit icmp echo” in IN ACL
Correct me if I am wrong.
Han,
You are the network administrator at ABC. You are troubleshooting a network problem. You want to trace the route to a Unix workstation that you want to reach through the Internet. However, Traceroute does not work.
Currently, there is an inbound access-list applied to the serial interface on Router 1. An entry in the access-list states "access-list 101 permit tcp any any". What access-list entry may you need to be added to the access-list in order to get traceroute to work?
A. access-list 101 permit udp any any
B. access-list 101 permit icmp any any time-exceeded access-list 101 permit icmp any any port-unreachable
C. access-list 101 permit icmp any any time-exceeded access-list 101 permit icmp any any net-unreachable
D. access-list 101 permit icmp any any echo access-list 101 permit icmp any any net-unreachable
E. access-list 101 permit udp any any access-list 101 permit icmp any any protocol-unreachable
Lab settings and results.
topology:
R3620--r1--pc
The basic running conf of R3620 is follwoing:
interface Loopback0
ip address 100.100.100.100 255.255.255.0
interface Serial1/2
ip address 3.3.3.1 255.255.255.0
ip access-group 101 in
access-list 101
10 permit tcp any any
20 permit udp any any (591 matches)
30 permit icmp any any=================question is from here.
then the result from PC without line 30 present--int on r3620 unreachalbe.
C:\>tracert 100.100.100.100
Tracing route to 100.100.100.100 over a maximum of 30 hops
1 <10 ms <10 ms <10 ms 192.168.1.11
2 3.3.3.1 reports: Destination net unreachable.
Trace complete.
the result from pc when line 30 present--works fine.
C:\>
C:\>
2 30 ms 30 ms 30 ms 100.100.100.100
Trace complete.
steve_steele Fri, 01/11/2008 - 01:01
Trace sends out a udp packet to the destination device with a destination port of 33434 (by default) initially with a TTL of 1 which increments as the trace continues.
In response each router on route will send back an ICMP time-exceeded message.
When the destination is eventually reached the device will not be listening on the udp port so will respond with an ICMP port-unreachable.
the udp needs to be permitted outbound, but inbound ICMP port unreachable and time exceeded need to be allowed through.
I'm prettty sure I'm right but there are a lot cleverer people on here than me that may prove me wrong.
Hope this helps
Steve
